Write to spreadsheet file. Option to write or not to write
Hello all,
I need to write to a file a 1D array using: "write to spreadsheet file". But I want to include an option for the user (in the front panel) to select to write the file or not to do it.
What is the best option for this?
Thank you.
(2,489 Views)
Accepted by topic author teach74
Hello
Create a Boolean button write and connect to a case structure and put the spread sheet inside case structure.
(2,468 Views)
