Write to spreadsheet headers?
Is it possible to put headers above each column in write to spreadsheet? Or at least I need the data to start one line further down...
Any ideas?
Message 1 of 13
(7,168 Views)
Like this
20727iA6E2AF8CC3B601B1
Tim
GHSP
Message 2 of 13
(7,156 Views)
Sorry.... that's no good, i need my numbers to stay as doubles unfortunately.
Message 3 of 13
(7,147 Views)
Are you trying to write to a spreadsheet file in tab delimited format or dirrectly to a spreadsheet application like excel.
If you are writing to a tdf or cdf then the above will work since all are essentially strings (ascii file), you can change the second %s to %.5f (change the 5 to what ever precision you need in the final file).
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 4 of 13
(7,139 Views)
Pazmush,
The spreadsheet will be text or strings.  That is the way the files work.  The code aeastet posted uses doubles - look at the wire color.  The example data all had integer values but was still a double representation.  Look at the help files for the Array to Spreadsheet String function for information about formatting to save as much precision as you need.
Lynn
Message 5 of 13
(7,138 Views)
20733i8DFB436258260E90Slight modification to allow for precision to be maintained on doubles.  You can also save in minary format or write to excel using a toolkit or activeX but this is more work.
Paul Falkenstein
Message 6 of 13
(7,128 Views)
ive got numbers that are like 1.34E-14, how do I go about encorporating them? So far i keep getting zeros
Message 7 of 13
(7,115 Views)
Use the Number to Exponential String function.  It is in the String >> String/Number Conversion palette.
Lynn
Message 8 of 13
(7,110 Views)
20741iD339697454C7A049
Message 9 of 13
(7,097 Views)
That is what I did
Message 10 of 13
(7,096 Views)
