Writing Array to Excel File, Channel Output order?
Bear with me, I am not very good with LabView, we have this code and I have made it so it will output to a excel file, with a time column and 28 channels. The problem I am having is how to identify what channel is what. Some channels are reading pressures or temperatures and some are inactive. But in the output file, some columns are completely filled with constants (when they most likely should have been reading 0, assuming they are the inactive channels).
Anyways, I am wondering if anyone can steer me in a direction that will help me identify what column in the output file is associated with what channel in the code.
If I am being unclear in anyway, please let me know. I have attached the .vi and .xlsx files.
(3,497 Views)
You have 29 signals that output in the same order you requested them in the DAQ Assistant so:
In terms of programmatically writing to an excel sheet with the signal names in the column headers, this takes place in the Export Waveforms to Spreadsheet File VI (double click on it and explore it for fun sometime). You would have to change the Export Waveforms to Spreadsheet File VI to do your bidding. I might make a KB and a community example on this so for your patience I will present a solution.
Ben J.
(3,443 Views)
Aforementioned Community Example
http://decibel.ni.com/content/docs/DOC-13832
Ben J.
(3,438 Views)
Seems to me that if you know what channels are what and they are not going to change during your aquisition
Just write the headers to the Excel file before you enter your DAQ loop
Or even right before you write the 2D data array, write a 1D array containing your headers.
=== Engineer Ambiguously ===
(3,428 Views)
(3,427 Views)
