Writing Data to a File
 Hello Everyone,
How can I have my data be written to the same file for a week and then automatically start writing to a new file for the following week? How can I make it write to the same file for sometime and then automatically make it write to another file for another period of time.
Thank you in advance,
Corina
(3,320 Views)
I do a simillar thing all teh time but for new files every day.
Use the Format Date/Time String function to keep track of the week number (in my case I look at the date) and change the file when the week nimber changes.
I have attached a screen capture of a code snippet so you can see what I mean.
=== Engineer Ambiguously ===
(3,302 Views)
Hello Corina.. 🙂
    I tried something in LabVIEW 7.1... Hope you are looking for the same... 🙂
Message Edited by Rupali on 01-10-2009 04:38 AM
(3,252 Views)
Hi Corina,
you can use a function to calculate the week number from the current date. Use the calcualted number in your path and you automatically get a new path for a new week. With this you don't need to remembe/check the last used path.
Mike
(3,223 Views)
