Writing Files on PDA
I am trying to write files following a DAQ operation. What is the best way to do it. I noticed that the PDA module does not support VIs such as write to spreadsheet.vi etc..
can anyone suggest what is the best way to achieve this?
I tried the write file.vi but it keeps writing junk.
Prasad
(5,186 Views)
Attach your code. The write file.vi has not given me such problems.
I think if you use text file with comma separated values, Excel will be able to pick it up.
(5,186 Views)
Sorry I must say that it also gives me some erroneous results.
(5,186 Views)
Here are two examples of how to do this:
Labview 7.0 PDA Module � File I/O � Pocket PC
Labview 7.0 PDA Module � File I/O � Palm OS
Hope this helps! Let me know if there is anything I can help with or clarify.
Ken S.
(5,186 Views)
Thanks for the help. I figured that the data node of the write file.vi accepts only typecast of formatted data. When i was reading the help this was not clear to me as it said that it takes in the data directly. I was able to solve the problem by converting the data from binary to fractional string before writing it.
Thanks again
Prasad
(5,186 Views)
