Writing LabVIEW program to communicate with ADAM-6217
I am currently working on extracting current measurements from a Rogowski coil that goes through the Adam-6217 Data Acquisition Module and subsequently goes into my laptop via a ethernet cable. I have never used LabVIEW before and thus, I need help as to on how to develop a program in LabVIEW that can read and analyze the current that comes from the Rogowski coil. Do give me any advice on how I should go about with this. Thank you.
(1,692 Views)
Hi Coil,
Read the manual of your DAQ module to learn about its specifications.
Then implement the code needed to communicate with that module…
Last week you already created a VI with some other DAQ device…
(1,641 Views)
