Writing a Hex string to a file
I am reading a hex value from the serial port, and I want to write this value to a file.  When I try to write the value now, I get the following:
ƒ0
XSRØ
But it should be:
8330 0D58 5352 D801 0000 1029 2822 1106 EC00 7F08 0400 5C00 0000 0000 0000 0000 0000 0000 0000 0D0A
I have tried the various converters in LabView, but have had no success.
Any help would be appreciated.
(8,682 Views)
It seems that what you want are the ASCII characters that *represent* the hex characters in your string.  There may be an easier way to do this, but the first way I thought of is shown below:
See if this helps.  I have also saved the VI in LabVIEW 7.1 format and attached it below.
Good luck,
-D
Message Edited by Darren on 03-22-200611:53 AM
(8,677 Views)
Thanks for the help!
(8,661 Views)
Well, it really depends how you want to look at it. 😉
You could just write the raw hex string to a file, then look at the file in a hex editor. 😮
(This is often the method of choice, especially if you want to read it again later with a program).
It seems you want ASCII formatted text showing each double octet with 4 digits (0...F), followed by a space. If your string always contains an even number of digits, you could just cast it as U16. This would simplify the code a bit. See attached modification of Darren's example (LabVIEW 7.1).
Message Edited by altenbach on 03-22-200611:11 AM
(8,662 Views)
Here you go:
(7,986 Views)
@Marcano7 wrote:
Here
1. You are replying to a 12 year old thread.
2. Your code really does nothing but give you the string you started with.  Not very helpful.
(7,977 Views)
@crossrulz wrote:
@Marcano7 wrote:
Here
3. Your code does not work for strings longer than what fits into a I32. Very limited and thus does not work for the original problem.
(7,960 Views)
