Writing a textfile from a network computer to another network computer.
It's possible to write a textfile from a network computer to another network computer via labview without using FTP?
(3,385 Views)
Accepted by topic author bebo_lm
Hi bebo_lm,
it depends on how they are connected. If you have "normal" access to the pc and you can write to a hard drive of the other pc, then you can use the write to file functions or copy file. If they are not connected like this, then you need another service. Why don't you like to use FTP?
Mike
(3,379 Views)
Hi Mike:
Because of requirements specifications.
(3,371 Views)
Just Another Question.
I'm trying what is attached and in both tries the following error comes out:
"Error 7 occurred at Copy in Untitled 1"
LabVIEW:  File not found. The file might have been moved or deleted, or the file path might be incorrectly formatted for the operating system. For example, use \ as path separators on Windows, : on Mac OS X, and / on Linux. Verify that the path is correct using the command prompt or file explorer.
I'm using:
\\networkNameForComputer\c\files\TextFile.txt
for the target directory
and
C:\files\textFile.txt
as source path
Why this error comes out?
Do my computers need a specified protocol for the file copy?
Thanks in advance!
(3,361 Views)
Are you sure you have user rights to right files to the other computer?
If you have a Windows Explorer window of each directory open (your PC and the networked PC), can you copy from one to the other without error?
(3,345 Views)
My networked computer was password protected.
Thanks!
(3,317 Views)
