Writing an array to spreadsheet with timestamp
Im using a Savitzky Golay filter to filter some noisy data. I fed the array output of the filter to an array to spreadsheet function and then to a spreadsheet string. What I wanted to do was to attach a timestamp to each data value in the array. But unfortunately, the time stamp gets attached to each row of the array. How do I attach a timestamp to each data value and then write to the spreadsheet file. Kindly help me out.
Thanks and regards.
(3,845 Views)
With out code it's hard to explain but you need to insert your timestamp eirlier in your program.
Like every time a reading is taken, take a timestamp and build the array with the timestamp as an element right from the start.
=== Engineer Ambiguously ===
(3,843 Views)
Firstly, i apologise for the late reply.
I dont really understand what you mean. The SG filter outputs an array at regular intervals, basing on the number of points used to implement the SG filter array. How do I attach a timestamp to each value?
(3,811 Views)
In LabView 8.2 you can create timestamp from the Palette see attachment
(3,738 Views)
