Writing array to selected row in array table
im stuck on trying to display a row of data which i took from a excel file.
just displaying the data on an array table has no problem BUT when i use Index Array and Replace Array Subset Function, no data comes out.
so here it goes, Table3 has the data i want but Table2 have no data at all.
im using Index Array and Replace Array Subset Function to allow me to SELECT the ROW of that i want to be displayed on
any idea?
21479iEBCF0826DDE2F79B
(3,659 Views)
Accepted by topic author 64864050
Hey!
Try this..
I use the reshape array function to change the row extracted from Excel from 2D to 1D. Then you can just straight replace this in your table.
 - Rkll
(3,639 Views)
Best guess is that "Table2 stereo" is empty to begin with.  You can't replace elements of an array that does not exist.
(3,633 Views)
Seems that you are doing it the hard way : why don't you use the array subset function ?
21489i10F4D04084144C2C
Of course, Wayne was right.
Additionnal comments :
1- you are misabusing the local variable
2- the index array function can be resized to have several outputs
3- then, no need to wire all the index input (autoindexing works here also...)
4- same comment for the index inputs of the replace array element function, if replacing elements on the same row
Chilly Charly    (aka CC)
(3,615 Views)
thank you all of you all
it was a great help!
(3,602 Views)
