Hi Momolxg,
I could be way off on this. I tried to simulate what you've done by
making a for loop that would run a set number of times. For my example I
used 1025. I wired the iteration terminal to a 'Write to SGL File.vi'
outside the loop with indexing enabled. It wrote the SGL data from 0 to
1024 to the file. I then read the file with a 'Read Characters from
File.vi' and searched the output for a carriage return (0D hex). It was
found five times. The reason why was the SGL number it was reading had a
13 (0D hex) in it. Perhaps you're running into a similar problem?
I tried it again, this time using the 'Write to I16 File.vi'. The
carriage return was found five times: the 28th character the first time
then on the 512th character four consecutive time
s after that. I suppose
that makes sense that you'd find a 0D in the numbers at equal spacings if
they're incrementing this way... In this case the carriage returns you're
seeing are actually numbers from your data.
One big difference is that I'm using a set pattern of numbers. This
doesn't appear to be your case. Is there a better way we can duplicate
your problem? It sounds interesting. Again my simulation could be way
off. (I'm also running this on LV60 for Linux so my results could be
different)
- Kevin
In article <5065000000080000002E610000-1031838699000@exchange.ni.com>,
"momolxg" wrote:
> Is there a VI for writing binary data to a file without carriage returns
> being inserted every 512 bytes? Thanks
