Writing binary data to a file without carriage returns every 512 bytes
In article <50650000000500000098AA0000-1031838699000@exchange.ni.com>,
"momolxg" wrote:
> Wonderful. I think you have reproduced my problem! It has nothing to do
> with your data set. Just try it with random data. I remove the carriage
> rturns so that I can read my data with a FORTRAN program and when I do
> so get data that matches what I see in LV. We have tried to understand
> from the documentation if it is necessary to have these carriage returns
> but have not found the means for turning it off. Suggestions welcome!
OK, I tried it with it with a random numbers. Now I find the carriage
returns in random locations. This is to be expected. Again, the only
thing I am seeing is the 0Dh, that's part of the SGL number. Sorry,
I
haven't simulated your problem.
Have you tried what I am doing with the string search after geting the
characters from the file? Verify that your carriage returns are really
every 512 bytes apart (witin labview). It should be random since you're
using random data. If it's not randomly spaced then something must be
wrong with your data source. Sorry I can't help further. Good luck.
- Kevin
Message 11 of 13
(596 Views)
Please send me your example with the Write_SGL_to_File.VI. The difference must lie there.
I do see carriage returns every 512 bytes.
Message 12 of 13
(596 Views)
I've attached my vi.
I don't usually use the NI forum (just news readers for me). Tell me if it doesn't come through cleanly and I'll email it to you.
-Kevin
Message 13 of 13
(596 Views)
