Writing comment to a tdms file during Data Acquisition as many times as required
Hi everyone,
I am trying to write a comment to a tdms file during Data acqusition at deasired time stamp.(Please find the attached doc).One which I did was able to write the comment only in the first cell of the Comment column.
I searches in the Forum about this Topic and found that qeueing is the solution and found no vi's related to it. Please help with a example to start with it.
Thanksa a lot in advance
(3,663 Views)
Hi Avalanche_27 (French ? If yes, you can also check the "francophone forum" !),
The Producer/Consumer pattern is very simple to use, but could be complex to understand.
To check an example, you can read this or that and begin a new project with the QSM Template (Manu page of LabVIEW -> Create a Project -> QSM Template). A lot of explanations follow the Template.
If you have some questions to understand how a Producer/Consumer pattern works, feel free to ask !
Bilsix.
(3,650 Views)
Hi Bilsix,
Thanks a lot for the info.  I ll go through them.
I came up with a logic with only while Loop. Please find the attached VI. It provides the Output how I require
I also want to log the data evey 10sec or 1min as the test goes for 2days. So, using a Producer consumer Loop logs every data as consumer Loop runs faster than the Producer.
Could you please tell me if the logic which I have developed is a right way to do it?
Thanks in advance
(3,630 Views)
I'm sorry Avalanche_27, I work with LabVIEW 15. Could you please send the .vi "saved for a previous version" ?
(Open your .vi -> File -> Save for previous version...)
Bilsix.
(3,610 Views)
Sorry for the late reply and for the Version Bilsix.
(3,602 Views)
