Writing data of HEX into EEPROM adresses with particular storage format
Hello jamiva,
I have done the logic as per your comments, now am able to get hex from value and format specification.
Thanks and regards,
Nafees
Message 11 of 15
(1,021 Views)
Accepted by topic author shaik89
I did one case for the inverse "Float to Hex" conversion for you. Easy to create other cases from this template. Just change the "Convert to.." function and the values of "f" and "e" as appropriate.
Just be aware that it is up to you to ensure that the floating point numbers fall within the valid ranges for the conversion type (i.e., trying to convert a negative number to an unsigned Format).
I doubt that you will be converting only one hex or one single number at a time. I modified the code slightly so that you can work on a large, multi-value bit pattern string; or an array of floating point numbers all at once.
EDIT: But it would all have to be the SAME conversion format
Message 12 of 15
(1,017 Views)
Can you save and share the vis to 2014.
Ali
Message 13 of 15
(1,007 Views)
@shaik89 wrote:
Thanks for you response,This logic was nice and simple it has reduced my code, but if i have some 35 to 40 storage formats i need to create this many cases still this works for me.
Thanks and Regards,
Nafees.... 🙂
Here it is. I included both conversions in one block diagram. As I said before, I only worked out one case for you. You need to do the rest for the other 40 or so cases.
Message 14 of 15
(1,001 Views)
I have created a  logic with four cases one for unsigned 8 bit, signed 8 bit , signed 16 bit, unsigned 16 bit by making f and e as controls.
Nafees
Message 15 of 15
(977 Views)
