Writing data to binary file byte issue
I am attempting to write a 22 channel array to a binary file. Each single-precision number in the array should be 4 bytes, so after writing to the file, I expect it to be 88 bytes in size. However, when writing the whole array to the file, it comes out to 92 bytes. I am not sure where the extra 4 bytes are coming from.
When I index the array and write each data point separately, it gives me the result I want (88 bytes). Ideally, I would like to be able to write the whole array rather than each point. Any idea what is going on here?
(4,151 Views)
Accepted by topic author arob
If you're writing an array, then it's probably adding in a header for the array that specifies the size.  Check the first 4 bytes, it probably decodes to 22 and then the rest of the data matches your data exactly.
(4,137 Views)
Yup, i was missing a false on the "prepend array or string size?" input for the write to binary file function
(4,127 Views)
