Writing digital data to spreadsheet
I want to write a digital waveform ( which is the output from the NI HSDIO Express - Acquisition) to an excel file. The NI HSDIO Express - Acquisition is inside a 'For' loop and it generates the digital waveform for every iteration.
I am currently, displaying the digital waveform in the 'digital waveform graph' and when the program is running, I right click the waveform window (in front panel) and select export -> Export data to Excel. But I want the writing to the excel sheet to happen iteratively without me doing 'Export data to Excel' for every iteration.
Can anyone please help me as to how to write the digital waveform output directly to Excel sheet iteratively?
(3,539 Views)
Use the Write Waveforms to File VI to write to a tab delimited text file.  Excel can open those up just fine.
(3,529 Views)
Thanks for that suggestion. But that works only for analog waveform. But mine is a digital waveform and it's conflicting the data type. So any other suggestion?
(3,477 Views)
That VI should accept the digital waveform.  Did you try to wire up a digital waveform up to it?
(3,475 Views)
