Writing file more 4GB
Hi.
I would like write datalog file data that contains array (size=1M of dbl data), strings and numeric. But when I reach size of file = 4GB I have an error that it's max file size. Is there a way to write such data and have output small size file? Thanks.
Message 1 of 12
(3,631 Views)
Hi Valentin,
you can write data to a file continuously, even with more than 4GB in total.
But you should just use the basic FileOpen/Write/Close operations…
write datalog file
Use basic file operations instead of these Datalog file operations…
Message 2 of 12
(3,615 Views)
That should work OoTB.
The max file size could be limited by your file system?
Are you simply attaching data, or do you keep an internal pointer? That pointer would need to be 64 bit.
Also, some express VIs might not use 64 bit pointers internally, and most of us wouldn't use them anyway. So if you do, that could be the cause.
It would help if you posted some code...
Message 3 of 12
(3,603 Views)
FAT32 has a 4 GB file size limit.  Maybe that's what you're running into?
Bill
CLD
(Mid-Level minion.)
Message 4 of 12
(3,584 Views)
Are you using LV 32 bit or 64 bit? Any chance you're running into memory issues?
Message 5 of 12
(3,571 Views)
The Write File+ (string).vi found in the deeper catacombs of some express VIs has a 32-bit file pointer. the input is not used in the express VIs I looked at, but it might be used in some.
Post some code, so we can help you better...
Message 6 of 12
(3,542 Views)
it looks like, write binary file is affected by this - I want to write an array of clusters as one file, containing the number of array elements in the filename e.g. dump_150000, dump 160000
in this scenario, when the file size is greater than 4 GB, the resulting binary file is much smaller than 4 GB
in this particular case, this limit is somewhere between 150.000 and 160.000 rows:
I hope, this is not a bug - so if this is expected behavior, does there exist a workaround?
I am coding on Windows 10 using Labview 2023 64 Bit
Message 7 of 12
(1,782 Views)
yes, there it is: https://forums.ni.com/t5/LabVIEW/LabVIEW-quot-Write-to-Binary-File-Questions-quot/m-p/3818462#M10788...
Message 8 of 12
(1,768 Views)
Hi Alex,
What happens when you write to the file in chunks of 10000 rows?
What happens when you open the file once and use the file reference for all following file operations?
Message 9 of 12
(1,724 Views)
in my particular scenario, a dump of 10.000 rows will work as fine as 150.000 rows
This was actually the crucial point - using  "open/create file" once and then iteratively "set file position, write binary file, get file position", keeping the file refnum from open/create in a shift register and closing it after the loop has executed.
Message 10 of 12
(1,691 Views)
