Writing strict type def with constant
Hi guys
I am facing a problem which is very strange to me.
I've got a strict type def control (ring, containing three items).
If I place one as Indicator and wire a constant to it (right-click the terminal, create constant), it works different in LabVIEW and as exe.
In the LV environment it works without any problems - the ring is set with the correct value. If I compile it, it doesn't work anymore.
I attach it in both ways. Normal vi (LV 7.0) and as exe.
What's the point I lost sight of?
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,792 Views)
This is a known problem, check the following:
http://digital.ni.com/public.nsf/websearch/34BB42ECBC41E22186256D5100660511
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(2,788 Views)
Thanks Paolo
In the small test app it works now - I assume it works also on the real app (the app-size increased about 2mb).
But as I read the article, this behaviour is required by ni, but I can't follow this at all.
Thomas
Using LV8.0
(2,779 Views)
