Writing to Excel file is very slow. How can I speed this VI up?
Hi Kirit,
yes please clarify. What do you try to do?
Mike
Message 11 of 22
(3,056 Views)
Old thread revival time! I seem to be having the same issue as the orignal poster. Each time I use the Excel Easy Text item, it bogs my program to a crawl. Can I use a 1D array to acheve the same thing by using the Eas Text function?
Message 12 of 22
(2,778 Views)
Hey Eric,
Yes you should be able to create a 1-D array then push that whole array to the Excel and only use that function once, thus speeding up your program.
Kira T
Message 13 of 22
(2,735 Views)
OK thanks.
I tired to do that and I get an error because it expects a string and I am sending an array to it. I apologize for my ignornace. I am a novice when using the Report Generation Tools as I haven't used it at all.
Message 14 of 22
(2,723 Views)
sounds like you might need to typecast what you are feeding to your Excel Easy Text vi. You can take a look at the examples given in the Report Generation Toolkit manual http://www.ni.com/pdf/labview/us/report_generation_toolkit.pdf You may want to take a close look at the "Advanced Operations and Formatting" section where it implements string concatenation and array string/number conversions.
If you are still having the same issue, post back with your code so we can take another swing at it. Thanks!
Aldo A
Message 15 of 22
(2,700 Views)
I can't seem to figure this out....
Message 16 of 22
(2,681 Views)
Hi Eric,
open the context help and move the mouse over the red cross on the wire to "figure it out". Smiley Wink
Message 17 of 22
(2,677 Views)
I believe I have figured it out, but I need to test it.
I've placed the array in the Array to Spreadsheet function and then placed the output to the Excel Easy Text vi.
Message 18 of 22
(2,655 Views)
All,
SUCCESS!!! But...while I have gotten the code to work, it appears that when the data is placed in the Excel file, the data is condensed to one cell and not the cells within the workbook. Is there something that I am doing incorrectly?
Message 19 of 22
(2,638 Views)
Hi Eric,
There's a good example in the Example Finder called "Excel Macro Example.vi".  Does this help?
Thanks!
Ryan
Ryan C.
Message 20 of 22
(2,621 Views)
