12-11-2014 10:06 AM - edited 12-11-2014 10:08 AM
I've posted this in the LV board, but realise it may be better suited to the TestStand one...
I want to write to a TestStand Station Global from within LabVIEW. I can read from Stations Globals using the method given here: https://decibel.ni.com/content/docs/DOC-11447 but can't work out how to write to them.
Is it possible? If so, how?
Any help gratefully received,
Dan
12-11-2014 10:09 AM
I've only used TestStand a handful of times, but can't you modify that example to use SetValString property (or any of the other SetVal properties) instead of the GetValString? Just a guess.
12-11-2014 10:10 AM
Yes, I'm in the process of trying that, but haven't had much luck...
12-11-2014 10:14 AM
There should be a TestStand palette in your LabVIEW. In there is a TestStand - Set Property Value.vi. There is also a TestStand - Get Property Value.vi. Those will make your life a lot easier.
12-11-2014 11:06 AM
I've had some luck - in so far as I can get LabVIEW to update a Station Global in TestStand.
What I'd really like to be able to do is update it on multiple occasions from within a single VI - see my attached example.
Is this possible?
