Writing to a single TDMS file simultaneously from different pieces of Hardware
I am trying to write to a single TDMS file from multiple sources. One source is MS/s and the others are just Samples/s.
I am not sure if the best approach is to simple create multiple TDMS files and combine the data aftewards, put all TDMS writes in the same while loop or create three seperate while loops but write to the same TDMS file in all of the loops. All three of these architectures have pros and cons so I am looking for the community to eliquantly help me to decide.
(3,593 Views)
The simplest way is to just write to the same TDMS file.  Use a different group for each sampling rate.  You could probably handle this properly with a single loop that just does the writing.  Just include some information in your queue data about which group the data should go into.  Be sure to do a defrag of the file at the end to reduce the file size.
GCentral
(3,567 Views)
I have the same issue, but I have hard time figuring out how to put 2 different data (as 2 different groups) into the tdms due to the fact that there is only one input for data in the icon.
I understand your solution but I do not know how to implement it, so I will appriciate if you could explain in detail or suggest a tutorial somewhere.
Thanks.
(1,573 Views)
Hi outis,
What about using two TDMSWrite functions, one for each group, one after the other?
(1,564 Views)
