Writing to an Excel Template without showing
Hi Nghtcrwlr,
use "SaveCopyAs", it works.
Mike
Message 11 of 15
(1,043 Views)
Do i need to change the close method to "Save copy as".? Theres no change ...see attchement
And also there is no option to choose another filename or path.
Message Edited by Nghtcrwlr on 07-22-2009 09:38 AM
Nghtcwrlr
Message 12 of 15
(1,038 Views)
i would use this method addionally. You have to connect a complete path to this input.
Mike
Message 13 of 15
(1,032 Views)
Hi Mike
Thankss.... its wrking perfectly. But in order to close the original workbook with out saving, i created another invoke node with method "close" and connecting a false case to save changes. But which reference do i have to connect to it? I connected the Reference from "workbook" in the beginning. but its not working. it still saves the original template with changes.
Nghtcwrlr
Message 14 of 15
(1,026 Views)
Hi Nghtcrwl,
use the same refnum as for the "SaveCopyAs" method.
See the attached example.
Mike
Message 15 of 15
(1,012 Views)
