Writing values to a csv file using LabVIEW
Hello LV Experts,
I am reading voltage and temperature values from an Adam 5017 and Adam 5018 respectively using Modbus Communication. I need to write this values to a csv file with datetime stamp, Voltage, Temperature . I tried "Read a text file IO", it is only writing a single value and stops. Can anybody give me some suggestions. I am a student and I am new to LabVIEW. Your support in this matter would be valuable. Thank you in advance :')
Message 1 of 13
(5,038 Views)
Hi Varghese,
Why do you use a read function when you want to write to a file?
How do you write to the file?
Why don't you attach your code?
Message 2 of 13
(5,020 Views)
Do you mean "Write Delimited Spreadsheet.vi"? Or the "Write To Measurement File" express VI?
Post what you have. A lot could be wrong and if we post code it's unlikely it will fit in your code.
Message 3 of 13
(5,010 Views)
- you need to convert numbers into string,
- for the date stamp use the function FORMAT Date time ,
separate them with coma and
- use the function WRITE DELIMITED SPREADSHEET, using Comma as separator, this function expects you to input an array of strings. so when you have your string ready, just use build array and wire your string as a 1 element array ,
Share your code if you still have issues.
Message 4 of 13
(4,973 Views)
Hello LV Experts,
I am reading 8 voltage and 7 temperature values from Adam device using Modbus Communication. Now I need to write these values to a csv file along with timestamp. I tried "Write text file" but I am only getting a single row and not continuous values with time stamp and also my headers are not getting written. I converted the numbers into string using "Format into String" but I am confused how to loop and which loop should I use to get continuous values. Is there any better way to write to csv?. I am attaching my vi and Block diagram here. I am a student and I am new to LabVIEW. Your help is greatly appreciated. Thanks in advance :')
Message 5 of 13
(4,926 Views)
Hi Varghese,
I don't see anything of this in your blockdiagram image. And I can't open your VI because of the LabVIEW version you use.
(Please downconvert to an older LabVIEW version before attaching. I prefer LV2019.)
Do you correctly handle the "append to file" input of the WriteDelimitedSpreadsheetFile function?
Message 6 of 13
(4,904 Views)
Hey, Thank you for the reply. I tried "write delimited spreadsheet". Now I am getting continuous values, but the date time is not visible in the csv and for each second, multiple entries are getting generated. I only want to write values every 10 seconds. Also I am unable to add headers to the csv. Please provide me with some more information. Thank you so much.
Message 7 of 13
(4,899 Views)
Hi GerdW,
Thank you for your reply. Please find the down converted version of my vi. I am unable to add Headers and to control the duration of writing. Thanks in advance.
Message 8 of 13
(4,884 Views)
Hi Varghese,
  1. To "add headers" you should write once to your file upon creation of that file and write your header row(s).
    In all later file writes you just append measurement data to the CSV file…
  2. You don't want to control "duration of writing", but "duration of execution"…
    There is no loop in your VI so it runs once and finished. When you want to repeat code (or parts of) then you need to place a loop in your code. Typically you initialize once before the loop (modbus communication, file creation), read data and save to file inside the loop, and finally close all references after the loop!
The date+time is clearly visible, but Excel indicates a "narrow column" with those hashmarks!
Because there is no timing in your VI.
How often/fast do you call your VI?
(I guess you use the RunContinuous button, which is WRONG for production stuff. That button/run mode is meant ONLY for debugging purposes!)
On your code: You could apply scaling directly on your array data, no need to index each element and scale it on its own by using so much duplicated code!
Message 9 of 13
(4,865 Views)
Hi GerdW,
Thank you for your help. I need some more details.
1. Should I use one more "Write delimiter Spreadsheet" and add the header before the appending "Write delimiter Spreadsheet"
2. Which loop should I use?. Where can I adjust the time of execution in the loop.
Sorry, I am little confused as I am new to this.
Message 10 of 13
(4,856 Views)
