Wrong and persistent VISA driver
We used to develop all our company applications with labview 2015 and 2015 drivers.
One day I wanted to test NXG, and the installation squeezed lots of 2015 drivers by replacing them with 2018 drivers. when uninstalling NXG the 2018 drivers were persistent.
problem: VISA 2018 doesn't work with windows 10 when compiled from labview 2015. so my new application doesn't work anymore.
I know it because I tested different VISA versions on a previous program. I was forced to use 2015 in order to make them work in W10.
problem(2): I uninstalled the 2018 driver, but it is persistent, even if I reinstall the 2015.
-in every project I deploy, with or without VISA nodes, I have no choice but ticking "VISA 2018" in the installation menu.
-even if I manually remove VISA from Programdata\National Instrument\MDF\productCache, the 2018 is stil suggested.
I cannot use another version of Labview. does someone has a solution?
thanks in advance
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
Message 1 of 1
(1,981 Views)
