Wrong encoding?
(3,231 Views)
Hello Neolkar,
It is some malfunction in LabVIEW example window, It may have got affected because of virus or malware. I suggest you to re-install labview once again, It will be better option
Vinal Gandhi, CLA
(3,226 Views)
Thanks Vinal_G, but I don't think so. This screenshot was taken from LV 2013, when I try this in LV 2012, it's ok, but in german.
Main problem is, that same problem is in LV Block editor, so I unable to read descriptions and labels on icons.
(3,209 Views)
this usually happend if you start using LabVIEW right after installation (without restarting the OS). Try to run installation repair and restart you PC. It might restore correct character set.
Ondřej K.
NIEE AE
CLA, CTA, CLED
(3,177 Views)
