Hi LVers,
to log incomming UDP messages I am using two files. The header (fixed
length) is stored in the first file and the message body (variable
length) is stored inthe second file. As an extension to the header
information I want to store the sctual offset (position of the file
pointer) of the datalog file. The "WriteFile.vi" is giving this
information as an output value.
While reading the headerlog I saw that the output value is sporadically
the same for two or three calls of the VI.
Thanks in advance for any help.
Hans J"org Beesterm"oller
