Wrting to lvm file and reading it in same loop
Hi
I am writing lvm file (10 samples in one loop at 1kHz) inside a while loop and displaying it.
The same data i wanted to read and display.
But the issue is that read vi reads first 10 samples in every iteration.
My objective is to synch the two charts and display same data in every iterations .
(3,005 Views)
Why do you need to write and read data from a file inside your loop?
Why don't you just branch the wire containing the data?
Btw. I don't think it's useful to display data at 10 kHz sample rate...
(2,986 Views)
me too has same objective .
Actually I am reading sensor data on a remote PXI target and sending to host pc .
(2,910 Views)
Hi DMic,
and what's your problem with this?
(2,892 Views)
