X Control Add two numbers
How do you have a Xcontrol with two numerical controls and add the numbers together and return them on the data output.
I created the two numerical controls, put them in an event for when they change, and write the output to the data and have it be passed as a variable to my program.
I can get the two numbers to add, update an indicator on the xcontrol front pannel, but it won't write to the data output! The output just reads 0!!!
What setting am I missing?
(2,978 Views)
Did you set the "Data Changed" boolean to true
(2,959 Views)
That did it!
Don't know how i missed that,Thank you, I really appreciate it.
(2,951 Views)
