X-NET CAN : How to test my communication right ?
Working with PXI 8513/2. LabVIEW 26016.
I have developped a CAN Driver and would like to test it.
I never implemented CAN communication so i am kind a noob with it !
I am using Port 1 for Read and Port 2 for Write in Frame In/Out Single Point.
My questions are :
1) Why do we need to connect an X-NET Database to intiate a CAN communication ?
2) Why do all Frame List specified into X-NET Database are sent at the end of my CAN init ? (I do a CAN Read in Timeout)
3) When Writing a new frame, CAN communication openned, i receive message error telling the X-NET session name is empty. Do i need to connect by hardware my port1 to Port 2 ?
I already read whitepapers CAN and wkipedia CAN !
BR,
Vincent
(3,389 Views)
Have you looked at the X-Net examples? Also, take a look at this getting started with x-net document https://www.ni.com/docs/en-US/bundle/ni-xnet/page/getting-started-labview-api.html
But,
1) You don't need a database, look at section 5 of the getting started document
2) This CAN init is something you wrote? It sounds like a problem with your VI, you would need to share it to tell for sure
3) You connect the port to an open session and use that session to read/write. Again, look at the examples or getting started
(3,377 Views)
I resolved my issue. Thanks for the tip. I didn't see Frame Stream needn't X-NET Database.
How does the property node "termination?" work ?
Let it "Off" made a single wire connection, let it "On" made a HighSpeed CAN wire with 200 ohm resistance termination.
Does it apply only with NI cables ?
Do you know a specific pinout in NI CAN cable with 200 ohm termination ?Didn't found any in datasheet
BR,
Vincent
(3,326 Views)
