X-Y-Graph in DIAdem 10.0
How is it possible to create a X-Y-Graph at DIAdem 10.0?
Creating normal Graphs including only Y values is simple, but how it does it work, if i have X AND Y values and i want to show the Y values not over, for example, the time, but over the x values, to get a curve?
Has anyone got an idea, then please help!!
Thanks, Thomas
(3,041 Views)
Hi Thomas,
You should ask your question on the DIAdem board.
But here's the answer, it is only possible in Report (not in View) to make a XY graph, and quite easy, select the X-axis data, than the Y-axis data and drag and drop this on the graph you wan t to use!
Ton
My LabVIEW Ideas
(3,038 Views)
