X,Y axes scale change in excel
In my VI i am using "set graph scale in excel" function to change the x,y axes but they are not getting changed.
I want to manually feed the min,max  values for x,y axes so that the data to be inserted into the graph should appear according to the x, y axes.
How can i do this?
For clarification i am attaching my VI "Graph_Decorations"
(2,723 Views)
I like to use ActiveX directly for this time of action.
See picture of code (part of a much bigger vi).
The text (gray box) is from the Excel macro editor.
I then just translate that into LabView ActiveX code.
(2,701 Views)
