X scrollbar color
The problem of the X scrollbar of wavechart is that it's a one-color-scrollbar and the contrast between the background and the foreground of that scrollbar is not strong enough.
So i tried to modify it using the "customize control" option. But i can't find the way to make it bicolor.
Can somebody help me?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,406 Views)
I couldn't see an obvious way of customising the X Scrollbar for colour contrast either.
Have you considered using a horizontal slide or scrollbar (LV8 only) to control your graph using property nodes?
Example attached in LV7.0
Hope this helps
David
(3,395 Views)
There is also the graph and chart on the classic controls palette. The scroll bars for these show a lot more contrast.
(3,387 Views)
Thank you very much for your help!
(3,384 Views)
