X310 connection with PCIe in windows 10
Hi, I am trying to connect x310 with windows 10 PC over PCIe. Now
  1. Its showing in device manager
  2. Showing in NI MAX
  3. Service for RIO devices is running as per windows task manager
  4. I cant figure out what is the name of device so I can use it in labview
  5. NI MAX is not showing name.
(1,331 Views)
I'm guessing the name is this part AeroSoul_0-1631862811474.png, it is a bit weird tho.
I have a NI PCIe-6341 and it simply shows up as "Dev1"
(1,318 Views)
I've seen this happen when the services that NI MAX depends on are not started.  They are:
They may not load at startup unless you set them to delayed startup.
Bill
CLD
(Mid-Level minion.)
(1,284 Views)
Thanks for all your replies. The issue was simple. I turned on USRP before turning the on the host computer, so host computer was not detecting x310
(1,256 Views)
