XControl Method - deprecate
Is there a way to deprecate a method in an XControl?
(5,295 Views)
Only if you can access the control's source code.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(5,242 Views)
Mike,
i think that Paul is asking if it is possible to mark a method of an XControl, which is available as invoke node, as deprecated (dark red/brown color) in the invoke node itself.
Is my assumption correct, Paul?
Norbert
Norbert
Expert: Geometry
(5,234 Views)
Yes.  I have the source code; I want 2 of the old methods to show up in pink.
(5,215 Views)
@paul_cardinale wrote:
[...]; I want 2 of the old methods to show up in pink.
If you talk about the VI icon itself, you can modify it. For the invoke node: I don't think that you can modify the color it uses....
Norbert
Norbert
Expert: Geometry
(5,212 Views)
Invoke nodes do have flags, but I haven't found a way to set them.  I tried guessing some items to insert into the .xctl file, but nothing worked.Invoke Flags.png
(5,132 Views)
I've never needed this functionality, but I can see why it might be useful.  I'd suggest posting this idea on the idea exchange so other users can vote on it.
(5,123 Views)
