XControl frontpanel freezes when timeout 0
Hi
I have an XControl with a big event handler (about 20 events currently). When I run this XControl for debugging ("Run Continuously"), its frontpanel freezes after only a few clicks, sometimes even directly after start. When I set timeout in the event handler to a value greater than a few milliseconds, it works.
The event handler is built as described here: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2jVCAQ&l=en-US
- Why does it crash when timeout is 0? Is this a normal behavior because the handler might take a few milliseconds to finish?
- Is it a good fix to just increase timeout to some 100 milliseconds or will I likely run into new problems?
Michael
(2,790 Views)
Can you tell me what is your version of labview and your OS.
Can you post your VI ?
Alexandre
(2,756 Views)
