XControl gets stuck on Property after build
@ChrisWeis wrote:
I guess the answer to your question would be uneducated.
I am happy about any suggstion you might have that helps me understand what clean up codes means in you opinion. Except for the facade Vi I just used the standard layouts? So are you talking about the facade VI our should I clean up the others too?
As for the Icon flag, it is true, since I put it together as an example.
Attached is a cleaned up version of your facade.
Message 11 of 12
(353 Views)
Thanks for your example of clean code.
Message 12 of 12
(321 Views)
