XControls Annoyance - 'Apply Changes to Instances'
I've been working with XControls a little, I find them a nice little way of displaying my class data...
However, I have this problem that when I load my project, I have to click 'Apply changes to instances' (as you can hopefully see in the picture) before I can run any of my VIs. Elsewise there are simply broken run arrows in my VIs.
Project
It doesn't make a difference if I apply then save my project and re-open.
It seems to effect all my XControls but not always at once. The problem consistent if I open a project, close it and open back up but if I work on the project, save then come back, sometimes its the same ones sometimes its different ones...I can't spot any predictable behaviour ...
Maybe I'm missing something silly or someone else has come across this?
LabVIEW 2012 btw
Many Thanks
Nick
(2,276 Views)
Hi Nick,
Welcome to the NI Discussion Forums, thanks for your post.
I haven't had this particular myself, but would like to investigate what is causing this. Does this happen with every XControl in any project? Or just this one?
If this only happens for this project (or similar ones) would you mind attaching the project in a reply?
Ben Clark
(2,211 Views)
