XControls don't show up in palette
Hello All,
I have an issue with XControls, they somehow don't show up in the user.lib palette... Even if I manipulate the palette via Advanced, and select the option 'Add custom control', it let me browse to the XControl, but it is not loaded onto the palette...Smiley Sad
Does anyone succeeded in adding XControls onto the palette?
Ton
My LabVIEW Ideas
(2,743 Views)
At least in LV 8.20 the following works for me:
- go to tools -> advanced -> edit palette set...
- Select controls
- Click to user controls
- Right click on empty space in user controls window
- Select insert -> custom controls
- > Browse for the xctl file you want to add
-> Click save changes in Edit Controls and Functions Palette Set window
That's it.
Tomi
Tomi Maila
(2,717 Views)
