XML Append Child - error 2603
I need to append a child to a XML structure from another XML structure. Labview 2011 pop-up the error 2603:
Internet Toolkit:  Node was used in a different document than the one that created it (that doesn't support it)
LabVIEW:  Used a node in a document other than the one that created the node, and which does not support the node.
I used the property append chils as well as in the figure I report. What is wrong?
(2,938 Views)
I can see two ways to do it...
TIP: to get the XML function to work properly you MUST ALWAYS close off ALL opened nodes.
If you have missed/forgotten to close off a node, shut down LabVIEW completely to release the open reference.
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
(2,925 Views)
