XML File syntax
Hello All
The attached vi shows an extract from an XML file. I can successfully extract the values of interest to me, such as Mean (the syntax I am using is shown on the left)
I now want to associate the value such as Mean with its key e.g. SENS0710:10951:IntSolIrr.
I've tried all sorts of combinations but have had no success. My vi works as suggested above, so I'm not after code refinements or corrections and that is why I haven't attached the code.
Could somebody please show me the syntax to use for the search expression to extract the key(s)
Thank you.
(2,760 Views)
Accepted by topic author rayclout
Ok....just posted and then hit the answer.........works fine now
Thanks anyway
(2,755 Views)
