XML array
I have a test channel cluster of 4 int values, 4 dbls, 1 enum and 1 boolean. Each cluster I flatten and save as an XML file. Flattening and saving and reading and unflattening are no problem. However, I have a 4x5 array of these clusters (20 test channels in all) and I want to flatten and save all these channels under the same xml file. Is there any way I can save an array of clusters with XML?
Paul
7.1
PaulG.
Retired
(3,328 Views)
Can you save them each individually to that file?  It sounds like you are really searching for a way to represent your array in an XML file, and I think that will be a design choice.  If I have misinterpreted something, definitely repost!  Perhaps you could have separate tags at the same level for each element of the array.
Best Regards,
JLS
Best,
JLS
Sixclear
(3,312 Views)
I need all the test channel data in the same file.
However, I think I solved my own problem. I'm testing it now. My test clusters are in a 1x20 array and I flatten to XML in a for 20 loop, cancantenate the output XML strings and save to the file. When I want to load my array from disk I read the XML file and index the XML elements as an array in a FOR 20 loop and use it to load my test data array. This XML is a little tricky since elements act like arrays but you can't auto-index and that threw me off a little. I'll keep you posted!
Paul
PaulG.
Retired
(3,309 Views)
That's great, in fact, that is essentially what I was suggesting when I wrote "Perhaps you could have separate tags at the same level for each element of the array."  Basically, you have a separate section of xml for each element of your array, which in this case is a cluster.
I hope your tests conclude with success of your solution!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,295 Views)
