XML error file not recognized when running VI
I've defined custom error codes using LabVIEW's error code editor. However, when I run my VI, the error handler VI cannot interpret my custom codes. My VIs are stored on a remote data server but I'm running LabVIEW locally on my computer. The XML file is stored in my local install directory>>user.lib>>errors. Could this be the problem? How can I get LabVIEW to recognize my custom errors without having to change where I store my files?
(3,012 Views)
I don't know what the problem was, but when I closed LabVIEW and then opened it again, it found my local error file...
(3,000 Views)
That is the expected behavior. The last line of the help topic says that a restart of LabVIEW is required.
(2,996 Views)
Thanks... guess I failed to read that part!
(2,981 Views)
