XML node array to multicolumn box
Hi everyone,I am trying to make a VI in which I am supposed to get a list of nodes from the XML file attached,then enter these nodes into a multi column box,apparently my V.l takes almost 3 seconds if my xpath expression is //*[sname='yup1']//fault from the time I click run to when I see the result in the multi column box but I want it to be instantaneous (am tryingto get the list of faults for the test with the sname "yup1" and then enter them into a multi column box)..any help with making it instaneous in that I click and then see the result in the multi column box instantly or atleast almost instantly?
NB;the file codx5.txt is originally codx5.xml.i had to save it to .txt because .xml files cannot be attached to questions please save it to .xml before using it!! thanks
(2,774 Views)
problem resolved...:womanlol:
(2,745 Views)
this how my v.i looks like now..i don't know why it's faster this way,,,it just is
(2,743 Views)
