XML parser RT
Have you tried LabXML? I use it in my apps. I don't know if it will work for RT, though.
Message 21 of 22
(2,374 Views)
The utilities I have should work for you, since you are not using any of the advanced features of XML.  They are attached below.  They are probably not linked very well, since I had to extract them from a library.  LabVIEW 8.0 format, although they could probably be converted back to about LabVIEW 5, if you had the patience and the versions of LabVIEW.  Let me know if I forgot anything.
Message 22 of 22
(2,358 Views)
