XML parser for Google maps
Hi every one,
I am trying to create a special format of an XML file for Google maps, I have a VI who takes the NMEA and sort out the parameters I need to create a track on the map, but I have try to make the XML file in LV but I get not right format of the XML.
This is how the file should look like :
file  data.zip
And how it looks like when I use LV :
file  LV_data.zip
Hope to try to find a solution 🙂
Lars Olov Jonsson
Space Electronics Engineer
Near Space Technology
WiFi Guru, proud holder of world record in WiFi, 421 Km @ 2 mbit/s
(3,945 Views)
Hi loj,
you can build the required format with the string functions.
See the attached example.
Mike
(3,897 Views)
You should check out EasyXML from JKI -- disclaimer: I work for JKI 🙂
There's a great example of how to generate a Google Earth KLM file (somewhat similar to the Google Maps format).
(3,864 Views)
Hi Mike
Many thanks, your sollution solved some of my problem 🙂
My Regards
Lars Olov
(3,840 Views)
