XML parser/formatter
Has anyone developer an XML parser/formatter for LV? I'd like an API that
allows:
1. to read in an XML file
2. search for specific tags/attributes
3. replace/insert nodes
4. save the XML back to disk
(4,690 Views)
You can use Microsoft XML parser for that. In labview you would be calling the MSXML ActiveX properties and methods to read/write the XML attributes.That would the best way to go with in labview. You can get MSXML from microsoft website for free.
(4,690 Views)
That's correct. I use that ActiveX Server from CVI and it works really
good. It provides a DOM (Document Object Modell) interface to
read/change/write XML documents. But you don't need to download that
from the microsoft website if you have a newer version ( >=5 I guess )
of Internet Explorer, MSXML is installed automatically.
In LabVIEW use the "Automation Open" Node and browse the registered
servers on your system. Normally its the last entry of the long list of
servers starting with "Microsoft..." and its named "Microsoft XML 1.0
Version 1.0"
Torsten Levin Tel.: ++49-(0)89-72495-451
Kayser-Threde GmbH Fax: ++49-(0)89-72495-291
Perchtinger Str. 3 mailto:TL@kayser-threde.de
D-81379 München http://www.kayser-threde.de
(4,690 Views)
Have you tried MSXML 3.0 with LabVIEV?
If you did please send me a simple VI which loads an xml file. I always get "Unknown System Error in XMLPhraser.vi" error with code 97. Any suggestions?
(4,690 Views)
I am trying to create and write an XML file.
I want to create a document and then add nodes as necessary. I have done this in VB, but when I do the same thing in LV it has an error.
Attached is the VB code and the LV vi.
A good link to reading an XML file is
http://zone.ni.com/devzone/explprog.nsf/6c163603265406328625682a006ed37d/6c414bdfe4c04f7086256a06007ad3f0?OpenDocument
Any help would be appreciated.
(4,690 Views)
Alex;
At www.openg.org you can obtain an XML-toolkit for LabVIEW
Regards;
Enrique
www.vartortech.com
(4,690 Views)
