XML
Hi all :
I want to build application to save variable "string" in XML file ,,  I want to update every day this file with new value .. so I want to add the new value under the old one etc….
How can I do that in labview
thanks
(3,456 Views)
Define the data type as array of string for the "Flatten to XML" and "Unflatten from XML" primitives.
Read in the file and unflatten the XML string. Then add the new string to the end of the array. Now call "Flatten to XML" and write the file.
Be aware that the XML file has a structure which is given by LV.
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(3,453 Views)
Hi :
thanks for you quick answer ..
can you help me with this issue
thanks
wisam
(3,445 Views)
Which LV Version do you use? The XML functions are on different palettes in differnt versions.
Waldemar
(3,421 Views)
There are also examples that ship with LabVIEW that show you how to write to XML. Open the Example Finder (Help -> Find Examples) and search for "XML".
(3,419 Views)
