XNET CAN Port not getting detected
          I'm trying to communicate with an XNET CAN card on a PXI Chassis. The interface between my PC and PXI is using ethernet. I'm trying to perform the basic CAN Read / write functions but for some reason the CAN ports are not detected in Labview. I can see the CAN card in MAX but im unable to see the CAN ports in LAbview environment. Any help would be appreciated.
Regards
Jay
(3,661 Views)
          Just a quick update, i'm not able to create a new XNET session in Labview 2014 whereas im able to open in Labview 2013, but tn the crete new session dialog the hardware doesnt seem to be detected? Any one knos of this?
(3,644 Views)
Not certain but it sounds like either XNet isn't installed, or isn't installed properly on either the host or remote machine.  I'd go into MAX and make sure both are the same version, then uninstall one or both, and reinstall.  I have not seen this myself so sorry if it doesn't help.
(3,638 Views)
