XNET broken down
Recently I have a problem with XNET 8513/2 and 9862, when I run XNET Stop for each frame output session then let ECU lost power, wait several seconds then run XNET Start for each sessions. Do above steps many times, XNET will pop up Error. If I want to recover XNET, I should be power on computer for 8513/2 and unplug and plug 9862 then can recover device.
Please refer to attachment error information.
And I found the same error in NI Example. Please refer to Transceiver Sleep Mode.vi. If I put node to sleep when messages are alive on bus, try this action two times, device will pop up the same error.
Message 1 of 1
(3,129 Views)
