XScale.Minimum does not work as desired
sorry but my English is not good.
I try to set the the Property XScale.Mininum of a Chart to value 0 and the Property XScale.Maximum to value 1000.
But the Chart displays the values ​​1000 and 1999???
In other chart i try to set the the Property XScale.Mininum of a Chart to value 0 and the Property XScale.Maximum to value 200.
But the Chart displays the values 800 and 999???
Can anyone help me?
Message 1 of 8
(4,029 Views)
Have you set the X-scale Offset to 0? or turn off autoscale?
Message 2 of 8
(4,019 Views)
I did both!
Message 3 of 8
(4,014 Views)
I mean, I had already done.
Message 4 of 8
(4,007 Views)
shot in the dark...
Try to right-click the chart and ensure "Ignore Atributes" is checked.
Done shooting in the dark,
Ben
Message 5 of 8
(4,006 Views)
I check the Property "Ignore Atributes" but still the same way.
Message 6 of 8
(3,999 Views)
Accepted by topic author geovane
A Chart set to the default Strip Chart and autoscale off will show you the most recent points.  The number of points is determined by the x scale.  When you initialize your chart you are setting the width, as you add more and more points you are simply seeing the most recents points, that is why the range of the xscale remains what you set, and the minimum value increases.  You either need to set the range after you have finished adding points or consider using a graph instead.
Message 7 of 8
(3,994 Views)
Thank you all.
Darin K.
I decided to use the Graph to solve my problem.
Message 8 of 8
(3,989 Views)
